Re: FARMALL 100 RADIATOR QUESTION
Posted by Hugh MacKay on August 13, 2006 at 15:20:05 from (209.226.247.176):
In Reply to: Re: FARMALL 100 RADIATOR QUESTION posted by NICK D on August 11, 2006 at 06:26:44:
Nick: I recored my 140 radiator 2 years ago, it's not a whole lot cheaper than new. Mine was $375. CAD. I am very happy with it. I wouldn't get to awfully excited about new radiators, some folks have bought them and they are not the right size. You local rad shop will get that right.
The SA rad will not work unless it's from a super A1. Super A1 is all SA after serial number 356001. The regular SA rad will be 2.5 inches shorter, about 1 inch narrower, thus the Farmall 100 sheet metal will not bolt up.
