Re: superh too rich
Posted by Bob M on August 14, 2006 at 04:42:41 from (151.190.254.108):
In Reply to: superh too rich posted by thirsty deere on August 13, 2006 at 19:41:50:
Several possibilities:
1 – Float level is set too high.
2 - The tip of the power screw is worn or bent so it does not properly restrict gas flow into the metering orifice (seat). Or a wrong (too short) power screw is installed.
3 – The carb has a main metering seat for distillate/kerosene (389 784 R1) installed instead of for gasoline (358 085 R1).
Screwing the power screw all the way to the seat on a good carb should lean the mixture sufficiently to cause the engine to stumble and even stall when the throttle is suddenly opened.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
