Re: HELP!!! Inside rear wheel width on Farmall A
Posted by CNKS on August 14, 2006 at 18:01:10 from (204.249.178.138):
In Reply to: HELP!!! Inside rear wheel width on Farmall A posted by AZ Bill on August 14, 2006 at 17:45:25:
You own the tractor and have no manual?? Specs for the rear wheel are 40,44,48,52,56,60,64,68. For front, same except lowest setting is 44 with standard wheels, if the rims are adjustable you can get additional ones of 40 3/4, 68,70. The 40 3/4 is with 4-15 tires, not 5-15. If you have larger tires minimum width is 48.75. Subtract one tire cross section width for the inside width. The manual tells you how to do all this, too complicated for me.
