Cub Tractor not Charging
Posted by Bernard on August 14, 2006 at 19:49:50 from (69.43.8.218):
Hi I need info on what I need to check on a 1952 cub tractor.It discharges what steps should I take to correct this problem.I know that you can check a generator by trying to see if it will motor.but when the battery is new and uses up all the charging in the battery the tractor quits running.would this be the voltiage regulator or volt meter or generator and help would be appreciated.When I pull out the start button it showes discharge and down hill from there on.Thanks Bernard
