Re: 340.
Posted by genep on August 15, 2006 at 12:04:36 from (216.96.7.166):
In Reply to: 340. posted by mike154 on August 15, 2006 at 09:55:42:
I had a 340 utility with the two point hitch. It had an independent PTO actuated by some type of band at teh rear of the tractor. Worked ok, though. My biggest beef with it was that the hydraulic pick up tube would lose suction when the tractor was tilted to the left. I'd have to get it to level ground and crack the pressure line to get it primed again.
