Re: fingers pressure plate
Posted by the tractor vet on August 15, 2006 at 14:11:39 from (75.24.20.100):
In Reply to: fingers pressure plate posted by scotty-mn on August 15, 2006 at 14:09:24:
Finger hight is preset , now did you remove the shipping bolts from the pressure plate ????? and did you make a clutch linkage adjustment along with a T/A adjustment ????
