Re: farmal super c
Posted by Will Sick on August 15, 2006 at 20:30:11 from (207.177.34.184):
In Reply to: farmal super c posted by Ch on August 15, 2006 at 19:13:26:
That is called blow by and is some water vapor and gasses that go by the rings. A small amount of this is normal and increases when the engine is under load.This helps to get rid of condens ed moisture from the crankcase. OIl fill cap has screen in it and should be washed in kerosene or a similar solvent and then a few drops of oil put on the screen. Also run the tractor under load or until it warms up good to get rid of moisture.
