Re: ever use PB Blaster?
Posted by Brad in WI on August 16, 2006 at 11:27:21 from (24.208.27.54):
In Reply to: Re: ever use PB Blaster? posted by old on August 16, 2006 at 11:13:54:
Can one of them rechargeable aerosal cans spray that ATF. That might be the cats meow if the ATF works as good as you say it does. All you need is an air compressor then to pressurize the spray.
Brad
