Re: ever use PB Blaster?
Posted by Nat 2 on August 16, 2006 at 11:31:56 from (64.80.110.35):
In Reply to: Re: ever use PB Blaster? posted by Allan In NE on August 16, 2006 at 11:03:51:
While I can't say how you're using it, I can say that the effects of any penetrating oil are rarely, if ever, instant. Penetrants need time to work; you can't spray the bolt then slap a wrench on it.
My personal experience with PB is on a very rusty H with many stuck bolts. Because it's out at my folks' place and I only make it out there about once a month, the penetrant has time to soak in and do some good. When I get a stuck bolt, I spray it with PB a few times, and come back a few weeks later. 99 times out of 100, the bolt is free.
The only instant penetrant is a good old flame wrench: An oxy-acetylene torch, and even those don't always work.
