Re: Farmall C Hi-Lo
Posted by Andy Martin on August 16, 2006 at 14:45:22 from (64.219.39.195):
In Reply to: Re: Farmall C Hi-Lo posted by Keith Weber on August 16, 2006 at 12:04:09:
Don't be too scared to take the carburetor apart. They go back pretty good with a broken gasket, I've done it enough times in the field.
A little exercise may help the governer. change the oil and keep running it.
Not wanting to come out of gear, however, indicates a clutch plate which is coming apart, the pieces drag on the pressure plate or flywheel and try to keep it engaged.
