Re: Char-Lynn for SMTA
Posted by GordoSD on August 17, 2006 at 06:45:33 from (66.115.200.140):
In Reply to: Re: Char-Lynn for SMTA posted by Allan In NE on August 16, 2006 at 07:48:26:
Allen. Thanks. OK, now forward of this plate there is a casting that holds the plate on and provides two circular supporting holes for the steering shaft and the throttle shaft. But it doesn't look feasible to use that casting unless you cut off the portion that supports the steering shaft. Is the entire steering shaft then supported only by that plate and the char-lynn divider?
Gordo
