Re: Glowing M
Posted by old on August 17, 2006 at 09:18:41 from (4.245.2.254):
In Reply to: Glowing M posted by chadd on August 17, 2006 at 08:11:32:
If the timeing is off or the advance in the disturbutor isn't working that is one cause. And or its running lean and that will also cause that problem. One other thing that will cause that is if the exhaust is clogged up. Seen more then one exhaust that a dirt dubber built a nest in and clogged it up enough to cause that
