Re: adding an extra reservoir to Lift-All on Farma
Posted by Andy Martin on August 17, 2006 at 12:14:41 from (64.219.39.195):
In Reply to: adding an extra reservoir to Lift-All on Farmall M posted by Loren P on August 17, 2006 at 11:55:37:
I think you'd be happier with a reservoir plumbed into the drain instead. Mounted above I think it would have to overfill the Lift-All.
Mine get hot running the round baler and Haybine. I have been considering adding a flat reservoir on the right side of the tractor with the four-way valve return going into the reservoir instead of into the Lift-All fill line, hwere some of it blows out the vent on heavy usage.
With the oil going into the new reservoir and then into the Lift-All drain, it should help keep it a lot cooler. I realize you don't have the return problem.
I was going to weld mine out of 1/8 or 12 ga plate but you could use a piece of 4-inch pipe alongside mounted at teh right elevation.
