Re: M Farmall locked left back wheel
Posted by Michael Soldan on August 17, 2006 at 16:14:10 from (24.235.41.226):
In Reply to: M Farmall locked left back wheel posted by Bill Zuke on August 17, 2006 at 08:29:50:
Bill, I'll bet even money its a brake froze on. You will need penetrating oil,a good heavy crowbar and a substantial hammer. The brake rod that activates the lining to the drum is rusted into the tractor housing. Normally there is a brass bushing on the end that fits into the trans housing. The iron on both sides of the bushing rusts, causing great pressure on the brake rod, almost like it was welded. You need to remove the bolts on the brake pan, I beleive there are 8. The pan will not move because the brake rod is siezed into the trans housing. You will need to saturate the end closest to the tractor with penetrating oil, then get the thin edge of the crowbar in behind the pan and against the inner lip of the brake rod, then drive it with a heavy duty hammer or sledge, keep prying and working the brake rod, it will eventually break free, I spent six hours breaking on free on an H. If you have a torch heat the brake rod red hot then douse with cold water, get a vize grip in the brake activating arm and try to move it as you hammer...they can be a pain, you will begin to think it won't ever come off, but keep at it and it will. Hone out the hole in the trans case, get a new brass bushing and grease it up good and reassemble..its a hell of a lot of work but its the only way..Good luck..Mike in Exeter Ontario
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
