Re: Farmall C Hi-Lo
Posted by Haas on August 17, 2006 at 18:24:49 from (12.65.60.206):
In Reply to: Re: Farmall C Hi-Lo posted by Keith Weber on August 16, 2006 at 12:04:09:
If the 1/8 hole you are talking about is on the distributor body and has 1/8 inch pipe threads, it is for a grease fitting to lube the distributor bearing. This only needs to be greased no more than once a year, and if you are not using the tractor regularly, every 5 years or so will do it. Over greasing is a no no, as that will get grease past the seals and into the distributor mechanism, not a good thing to happen. There is supposed to be 1/8 pipe thread plug in the hole. The orignal plug is slotted for a screw driver blade
