Re: timing advance
Posted by the tractor vet on August 18, 2006 at 16:49:57 from (75.24.20.100):
In Reply to: timing advance posted by wes in Ohio on August 18, 2006 at 15:13:47:
They should move out as dist speed increases , you should be able to grab the points cam and move them and then let go and it should go back .
