Farmall Tractors Discussion Board
Re: Hey Medfarm!
Posted by Paul Fox on January 24, 2000 at 06:07:18 from (209.222.216.5):
In Reply to: Hey Medfarm! posted by Dick Davis on January 24, 2000 at 04:45:40:
Not to steal Medfarm's thunder, but "grenaded" originally meant that the engine looked like somebody tossed a grenade in the oil pan. This is usually the result of a connecting rod or crankshaft breaking and punching a hole in the block.
I believe it originated in hot rodding/drag racing, where high RPM engine failures tend toward the spectacular.
Nowadays, the term pretty well applies to any major engine failure.
Post A Followup
: Re: Re: Hey Medfarm!
