Re: M Farmall not getting fire to plugs
Posted by John T on August 19, 2006 at 18:57:42 from (66.244.90.5):
In Reply to: M Farmall not getting fire to plugs posted by Bill Zuke on August 19, 2006 at 18:26:40:
Bill, is the Ignition a battery powered external coil ignition orrrrrrrrrrr is it a Magneto??? If it ran with no battery its gotta be a Magneto (requires no battery voltage to it)
Some Magnetos indeed have a kill switch which grounds out the points circuit when OFF but battery powered coil ignitions require voltage appled to the external coil via an On/Off Ignition switch.
If its a coil ignition I can give you a troubleshooting procedure but if its a Mag Im out to lunch except to check to see if it snaps and the kill switch circuit (if it has one) is okay n not shorted out and the points gotta be gapped correct and NOT burned or pitted or carboned over and the condensor has to be good n not shorted etc.
John T
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
