Re: Splitting a farmall H (need help)
Posted by mattlan on August 19, 2006 at 20:03:14 from (65.101.90.245):
In Reply to: Re: Splitting a farmall H (need help) posted by RustyFarmall on August 19, 2006 at 17:38:13:
here is what i usually do, I soak the tractor with what ever is handy. Mainly diesel. I usually don't have the tractors at my shop so when i buy them i start soaking them, even fill up the manifold wait about a week and then go load it on a trailer make sure all tires are up. Leave put the tractor in high gear, (hope the clutch doesn't slip and leave the chains a little loose. Usually (so far 9 out of 11) it is loose by the time I hit hte shop. You need to make sure that you have blocks fastened to the trailer so the it doesn't roll of it it brakes loose. You should try it. I am a shop teacher and this is by far the easiest way. I think if you pull motors you have a harder time unless you can get it in a press. I have broken off a spark plug and welded a air chuck on it and used oil presser to push the piston down. some use hydralic press. what ever works.
matt
