Re: trying to get a 1948 m to run again
Posted by old on August 21, 2006 at 09:14:32 from (4.244.57.5):
In Reply to: trying to get a 1948 m to run again posted by derek schwarting on August 21, 2006 at 08:36:15:
Well as rusty say the starter drive is probably stuck, I've never had any luck rocking a tractor to get them to pop free I have always had to pull the start and reinstall. As far as it not running you left out to important thing you should have replaced when you did things. You should install new points and condenser.
