Re: trying to get a 1948 m to run again
Posted by John T on August 21, 2006 at 09:31:57 from (66.244.90.5):
In Reply to: trying to get a 1948 m to run again posted by derek schwarting on August 21, 2006 at 08:36:15:
Derek, I kinda see the dying and now not cranking as possibly two seperate issues. My first guess on the dying would be a clogged up fuel delivery system like the gas out of the tank or into through n out of the sediment bowl or the carburetor (needle n seat n float assembly dirty/clogged/corroded). See if gas flows good to teh carb??? My guess on the non cranking is the same as Old n Rustys good advice, i.e. I also would remove, clean n wire brush n reattach each n every battery n starter n ground n starter switch connection n see what happens and if the starters drive is mechanically stuck/jammed as they mentioned, when trying to crank it the lights would dim down drastically and/or the starter get like really hotttttttt. If the starters NOT mechanically stuck/jammed (loosen bolts n rock etc) but still no cranky, see if the lights dim down when trying to crank???? If so I suspect the starter is bad (shorted armature) but if not, I suspect a bad starter switch or else it could still be the starter (worn/stuck brushes, try hammering on it???) Let us all know what happens best wishes, John T
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
