Re: Behlen power steering unit
Posted by Keith-OR on August 21, 2006 at 12:41:34 from (207.200.116.5):
In Reply to: Re: Behlen power steering unit posted by RoninKS on August 21, 2006 at 09:09:48:
Ron, the only problem I can see with using the belly pump, is I don't think it is classified as live hydraulics. So that means when ever you engage the clutch it stops belly pump from running, and no power steering during that period.
You can use your PTO pump to run your power steering also. that is the way I am running my power steering and FEL as my live hydraulic pump lost the seals and I haven't had time to replace them. Way I hooked mine up, is I plumbed the Flow Control valve before FEL spool valve. I then used the "CF"(control flow) outlet on valve, to my power steering unit. I hooked up line to FEL spool valve to the "EX"(excess flow) output on the Flow Control valve. After I got everything hooked up, I started tractor and adjusted FCV so power steering worked well, all the rest of the hydraulic fluid runs the FEL. I haven't noticed any restrictions on operation of my loader.
On my tractor I had no choice to use pto pump untill I had time to fix tractors hydraulics, with no hydraulics I could not steer tractor AT ALL, Hydro-static steering!!...HTH
I know, Clear as mud!!!...LOL
Keith & Shawn
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
