Re: 1206 injection pump
Posted by the tractor vet on August 21, 2006 at 13:25:23 from (75.24.29.127):
In Reply to: 1206 injection pump posted by 515ryanh on August 21, 2006 at 08:06:08:
On the right hand side of the bell housing there is a plate with two 1/4 inch bolts (7/16th) wrench size and under that plate is a timming pointer and on the flywheel it is marked off in degrees . Remove the two littel screws on the timing window and remove the plate make sure that you shut off the fuel at the tank first before doing this , Line up the two lines in the pump timing window and look at the flywheel it should be set at 8 degrees . Now on most 806-1206 with the D361 or DT 361 the things that make them hard starters are (1) slow cranking speed because of low cranking voltage or amp , Slowcranking speed because of a starter that is just about plum wore out. (2) low cranking pressure in the injection pump , (3) low cracking or breaking pressure in the injectors , (4) Low compression due to a wore out engine or valves wareing into the head thus lowering the compression of the engine . Also valves being to loose or to tight .
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
