Re: wide front for H or M
Posted by Buddy Martin on August 22, 2006 at 10:42:01 from (68.157.198.127):
In Reply to: Re: wide front for H or M posted by randy hall on April 12, 2005 at 20:30:15:
The same wide front end conversion will fit an H as well right? I am in the market for one. The condition is not really critical as long as the steering portion is sound. Bent or worn axle tube and such isn't a problem. I would appreciate any info you can give me on where to find one. The tires off the tricycle front end bolt up to the wide front end right? I'm in Tennessee but if I found what I need Ohio isn't to far to travel. Thanks.
