Re: How to change tire on M??
Posted by Bob M on August 22, 2006 at 10:55:49 from (151.190.254.108):
In Reply to: How to change tire on M?? posted by Granger on August 22, 2006 at 10:09:34:
I'm presuming you have cast front hubs with 3 bolt centerless rims...
Anyway they can be a PITA to get off - sort of a Chinese puzzle kinda thing. But the wheels WILL come off over the hub.
First jack the front end - jack under the belly pump - or run the good tire up on a block of wood. (For safety chock both in front and behind both rear wheels and set the brakes...)
After removing all 3 wheel bolts, position the wheel so one of the lugs is in 3 o'clock position. Then lift the wheel, move it forward so the front lug clears the hub. Now wing the front side of the wheel toward you, then lift and move the wheel toward the rear of the tractor and off over the hub.
Good luck - with patience it will come off!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
