Re: 5288
Posted by 430WLPG on August 22, 2006 at 17:02:04 from (12.25.127.91):
In Reply to: Re: 5288 posted by David Glenn on August 22, 2006 at 15:53:48:
You should have one soleniod engaged for one side and the other for the other side. But,if you can stop the tractor in gear without stalling the engine There's a clutch slipping somewhere and those odd and even won't take much slipping to be fried. may have lost bearing preload on the clutch shaft and losing pressure there, those tractors aren't easily serviced internally without the nessary stands and skates,everything is heavy. Your best bet is to contact your local Case-IH dealer that is familar with 88's.And get them to run some pressure tests And if it's internal it will be expensive!!!!!!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
