Re: Gasket 101
Posted by Hobo,NC on August 22, 2006 at 18:59:28 from (67.141.239.121):
In Reply to: Gasket 101 posted by bobcd on August 22, 2006 at 14:24:59:
Do not put enny thing on cork that will make it slippery, The cork will squeeze out and break. Its ok to put silicon on joints but not on all the cork gasket. Copper coat would be ok but let it have sum time to git tacky before you install. I glue 1 side with 3M 8001 adhesive, seal joints with black or gray silicon. Reason I use 3M 8001 izz to hold the gasket in place during instillation, it also needs a few min. to set up and depends on temperature, hot it sets up fast cold may need 5 min to set up. It izz tempting to install with out adhesive and may werk with out enny problems were you are at cuzz the gasket does not werk in a environment were their are positive or negative presser like were gaskets have to live on a engine. Cork will live a long time if it izz not affected by heat. Were heat izz a problem I had rather use a good silicon. Make sure yet sealing surface izz flat and clean as possible.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
