Re: Farmall M brake adjustment
Posted by Andy Martin on August 23, 2006 at 11:37:02 from (64.219.39.195):
In Reply to: Farmall M brake adjustment posted by garry lee on August 23, 2006 at 10:51:05:
The band is loose around the brake drum. The bolt in the bottom is used to hold the band up to keep the top of the band from rubbing on the brake drum before you apply the brakes. Adjust the bolt on the bottom after you get the pedal travel you want.
