Re: Putting sheetmetal back on .
Posted by glennster on August 23, 2006 at 15:07:04 from (68.77.132.170):
In Reply to: Putting sheetmetal back on . posted by rotax on August 23, 2006 at 06:19:19:
you can add shims under the radiator to level the hood from left to right, and use the support rod for front to back tilt. also you may need to add shims under the front of the gas tank. i use an old mudflap off a truck and a hole saw to cut out shims. 1-1/2 hole saw works good, you can slot the washer so you can get it in wothout pulling the radiator or fuel tank off. the other thing to check is where the front bolster bolts to the frame rails. there is some play there also
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
