Re: power steering on IHC 300 utility
Posted by bud woodland on August 24, 2006 at 06:59:15 from (142.68.223.54):
In Reply to: power steering on IHC 300 utility posted by bud woodland on August 20, 2006 at 11:53:03:
hey red
how are ya ,
i have the two fittings for the hoses from the priority & regulator valve and the two steel lines to the drive piston at the bottom but ..... there is another elbow fitting at the top that is actually rubbing on the gas tank .i don't remember this elbow being there before i took the unit off and sent it away for overhaul two years ago. it sure wasn't rubbing before , i thought maybe it had a flat plug in it. a plug would give it a 1/2" clearance between it and the gas tank .thanks for any info you might have .
bud
