Re: Super A Transmission Problem
Posted by Jim Becker on August 24, 2006 at 18:00:26 from (71.96.8.31):
In Reply to: Re: Super A Transmission Problem posted by Hugh MacKay on August 24, 2006 at 04:28:06:
If the problem happens while shifting gears, the problem may be wear on the tip of the shift lever and the forks. The lever may be escaping out of the notch in the shifter fork before it is in the neutral position.
The fix may be to build up the tip of the lever with a welder then grind it into a reasonable shape.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
