Re: 350 I/H
Posted by Janicholson on August 24, 2006 at 20:36:28 from (66.173.50.41):
In Reply to: 350 I/H posted by Les Lanyon on August 24, 2006 at 20:04:51:
Assuming it is a utility, not a row crop tractor, the hydraulic situation depends on what is there already. Again assuming it has a pump and maybe a fast hitch drawbar. The two front levers to the right of the seat are for add on hydraulic attachments. They should be plumbed in a similar manor to the FH cylinder for two way, and with a single hose for one way control. The single acting cylinder needs to be setup with the valve control switch set to single acting. A manual will help describe these connections, as well as limitations and switches. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
