Re: Farmall A Year
Posted by scotty on August 25, 2006 at 04:45:06 from (199.231.49.128):
In Reply to: Farmall A Year posted by CaptCarl on August 25, 2006 at 03:29:52:
Mornin Captcarl,
You cant go by the PTO size, I have a 42 A and that has the smaller PTO. Try cleaning the area on the engine right under the #1 spark plug there should be a serial # stamped there. Providing that its the original engine you can get a date. Also you can check your casting numbers on various parts pf the tractor. My 49 Super A has the larger PTO and Im not sure where the change was made. Im sure someone on here has that info. Good luck!
scotty
