Farmall B Clutch
Posted by Ohio Mark on August 25, 2006 at 19:26:06 from (207.58.195.3):
When I push in the clutch, sometimes (about 50% of the time) it will not fully disengage. I adjusted the clutch operatoring rod inside the clutch housing tube and also greased the clutch release bearing but it did not improve the performance. There are no unusual sounds when the clutch is either in or out. Any thoughts as to what the problem might be? - Thanks.
