Re: WTB c hydro-lines
Posted by gene bender on August 27, 2006 at 04:05:38 from (67.55.226.214):
In Reply to: WTB c hydro-lines posted by JD dozer mike on August 26, 2006 at 09:46:51:
The connection between the pump and lift arms it steel. So if yours has been changed to hose just replace with same size. Its always better to use bigger on the return than the pressure side.
