Re: 434 Draft control problem
Posted by Fromjb2 on August 27, 2006 at 08:02:03 from (69.198.143.165):
In Reply to: 434 Draft control problem posted by Chuck in Ohio on August 27, 2006 at 04:40:20:
Chuck, as I remember the rod that stuck out by the top link bolt was controlled by the draft control lever. If the draft control lever was set to heavy draft, all the way forward the rod did not stick out much and light draft it stuck out far enough to contact the top link mechanism.
Apply some lubricant as suggested by Hugh and work the draft control lever back and forth.
JB2
