Re: M 4 1/8 piston help
Posted by Dave Slater on August 28, 2006 at 16:07:54 from (152.163.100.65):
In Reply to: Re: M 4 1/8 piston help posted by randy hall on August 28, 2006 at 15:07:34:
Randy, I have found fire 4 1/8 crators in SM with big wrist pin. Number on piston is 374457 R1.
sleeve set # 374456 R 91. They have higher peaks than standard fire crator used with 400 450 gas head.Do you show this #? Also some manuals show these pistons as having small pin but have found big pins. As far as pulling,this is just my opinion, the fire crators were sold for working tractors and wouldn't be the best if short pull is all thats used.
