Re: 300 Utility steering gear value
Posted by wes in Ohio on August 30, 2006 at 14:48:19 from (12.4.26.248):
In Reply to: Re: 300 Utility steering gear value posted by JayWalt on August 29, 2006 at 19:49:45:
by no means am I an expert on these old tractors, what I have seen the differences between a 300 and a 300 U is the 300 U is physically smaller and it seems like every 300 has had a narrow front On my U it has an emblem under the 300 that says utility. U's were built in 1955 and 1956 only, the serial number will be on the transmisson right behind the oil filter.
I got my p/s unit from a fella in canada his motor blew so he was parting it out, I paid around $600 for it (shipping included) hard to find, very expensive, but what an huge improvement. I had to take my sediment bowl off my gas tank and run an inline filter that was the only clearance issue, besides he P/s unit you will also need a priority valve and all the plumbing, fortunatly I work in a hydraulic valve factory so it was pretty easy for me to make all the hoses and fittings I needed.
right now I'm looking for a good loader for my tractor I think I found a couple just can't afford yet.
I know right where fostoria is I believe our district wrestling tourney was in your high school back in the day.
Wes
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
