Re: No lift, no steering, no luck
Posted by K.B.-826 on August 30, 2006 at 21:34:39 from (24.180.130.55):
In Reply to: Re: No lift, no steering, no luck posted by Gary in Mozarks on August 30, 2006 at 20:06:09:
Don't take the pump apart until you've inspected any relief valves or dump valves in the system. I'd be willing to bet just about anything that you've got a stuck valve somewhere.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
