Re: B farmall water pump
Posted by Red Dave on August 31, 2006 at 04:56:56 from (24.104.94.34):
In Reply to: B farmall water pump posted by Tracy G on August 31, 2006 at 04:35:37:
I put a Super C water pump on my 1940 B. Direct bolt-on, it only needs the longer Super C fan belt to make it work.
There are two drain outlets on the bottom of the water pump. you will have to use the opposite one that a Super C uses. All you have to do is swap the plug from one hole to the other. I also had to grind the plug down some to clear, but not a big deal.
Depending on the arrangment of the top bracket of your generator you may have to modify it a little bit. I found that mine fit by bolting it to the back of the water pump and using a Super C generator belt too.
