Re: B farmall water pump
Posted by Red Dave on August 31, 2006 at 15:32:19 from (66.109.234.125):
In Reply to: Re: B farmall water pump posted by Jim Becker on August 31, 2006 at 14:00:16:
I tried that, it doesn't work.
The Super C water outlet is 2-1/2 inch diameter, and the B radiator inlet is 2 inch. Also the water outlet from a Super C will bolt on the B block, but it is longer and comes out at a different angle than the one from the B.
The Super C water outlet and the B radiator won't match up.
Would sure like to have any good ideas anybody might have that could work though.
