Re: Carb settings
Posted by Bob M on September 01, 2006 at 07:15:05 from (151.190.254.108):
In Reply to: Carb settings posted by Guff on September 01, 2006 at 06:27:31:
Guff - Last things first: Forget about using a lead additive! Your tractor doesn’t need it. Besides - any “lead additive” you can buy today does not contain lead anyway. ---- Now to your carb adjustment questions: When looking at the carb from the left side of the tractor there is a small screw w/spring at the top that goes in towards a tube coming from the governor. This is the carb throttle stop (slow idle speed adjustment). Turn it in to increase or out to decrease the slow idle speed ---- There is a yellow painted screw w/spring at the nine oclock position that screws in from left to right(air / fuel mix?). This is the idle mixture adjustment. With the engine warmed up and idling, turn it in/out as required for the best (smoothest and fastest idle). After setting the idle mixture you may need to return to the throttle stop screw and bring the idle RPM back down where you want. ---- There is another yellow painted screw w/lock nut, at about a 45 degree angle on the bottom of the float bowl (fuel level adjustment?). This one is the high speed or “power” mixture adjustment. With the engine warmed and at slow idle, quickly pull the throttle wide open. If the engine stumbles at all turn the screw ¼ turn CCW at a time and try again. Repeat until the engine picks up without stumbling. However the exhaust shows any black at full RPM turn the screw CW slowly until the exhaust just clears up. ---- There is one more small screw at the very top on the right hand side that is srewed in and bottomed out, not sure what it is for? That one’s actually a plug at the end of an internal carb passage. Remove it only if you have the carb apart for cleaning – otherwise leave it alone. --- Hope this helps...
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
