Re: Sleeve removal
Posted by Janicholson on September 01, 2006 at 10:44:06 from (199.17.6.122):
In Reply to: Sleeve removal posted by Gauger on September 01, 2006 at 10:30:02:
They should be tight enough that freezing the sleeves and using the install tool is required. In my opinion, If they are easily inserted by hand with just a tap or two while at the same temperature, they are too loose. Seperated sleeves can often be found in the crankcase from cracking, overheating can occur from poor heat transfer, and expensive engine repairs will result. These are pressed in sleeves. You may need to use sleeves sized for "C" "D" original bores (usually stamped on the block next to the sleeve ring.) Good luck, they are not a hand push fit at all. Jim Nicholson
