Re: Carb Question for John In CT
Posted by RustyFarmall on September 01, 2006 at 11:04:54 from (199.120.81.215):
In Reply to: Carb Question for John In CT posted by neblinc on September 01, 2006 at 07:42:21:
Before you do anything, trial fit the new throttle shaft in the old bushing. Most of the new, replacement throttle shafts are just a tiny bit oversized to compensate for wear in the bushing.
