Re: Dead battery on Super H
Posted by Bill in New Brunswick on September 01, 2006 at 17:06:38 from (142.167.64.137):
In Reply to: Dead battery on Super H posted by greg superH on September 01, 2006 at 16:07:51:
Not sure what alternator you used but did you run the wire that starts your alternator charging thru your switch or key. If this wire remains live after the motor stops it will be a draw on the battery.
ttfn
Bill
