Re: Dead battery on Super H
Posted by old on September 01, 2006 at 17:25:53 from (4.245.7.62):
In Reply to: Dead battery on Super H posted by greg superH on September 01, 2006 at 16:07:51:
Sounds like you have the alternator wired wrong. You need to have the #1 wire from the plug going to the switch, the side that is hot when its turned on not the side that is hot all the time. You also need to have a diode or light bulb wire in so you can turn the engine off.
