Re: A cracked block?
Posted by Merlin on September 01, 2006 at 22:50:25 from (209.205.160.100):
In Reply to: A cracked block? posted by Andy2006 on August 31, 2006 at 16:37:50:
You can also take a bolt out of the front cover in front of the crack and drill through the bolt hole and on through the crack into good metal and tap it. When you tighten it up it will close the crack. I too squeeze some JB Weld into it before I tighten it back up. You will have to take the front end off, but you will probably have to do that anyway.
