Re: Live Hydraulics on an H or M
Posted by T.B.W. on September 02, 2006 at 11:09:16 from (4.248.247.179):
In Reply to: Re: Live Hydraulics on an H or M posted by Dan Bear Kelley on September 02, 2006 at 09:21:06:
I got my hoses from tractor supply and the fittings from northern tool.It helps if you have a swivel on one end of each hose. I also used northern tool 3 gal. Hyd tank and mounted it on the axle and put a filter in the system. Some people use the belly pump for a tank, but mine was leaking and I didn"t want to fool with it. I love the live pump. It has a lot more power than the belly pump. I can lift a round bale with the loader with no problem
