Re: 2 questions on an M
Posted by janicholson on September 03, 2006 at 06:19:09 from (66.173.50.166):
In Reply to: 2 questions on an M posted by Bill Price on September 02, 2006 at 22:13:57:
We need to know if it is missing, or just smoothely getting weaker. If it is smoothely weeker I believe timing and coil are less likely (more likely a fuel mixture issue, try turning out the high speed jet 1/4 turn at a time, If choking it helps for a second or two it probably is fuel related, durty carb, or delivery).
If irratic and rough, it may be distributor shaft wear, or as noted a deteriorating coil. If the coil has no ballast resistor, or is specifically for a no resistor 12v system it could be the problem. If it is so hot that you would burn your fingers when it begins to slow down I recommend a new coil, and a ballast resistor in line with it. See Bob M's fine wiring diagrams for resistor application. JimN
