Re: 1466 clutch or transmission bearing noise
Posted by Sheepdog in NE on September 03, 2006 at 18:58:04 from (67.0.14.76):
In Reply to: 1466 clutch or transmission bearing noise posted by Steve Mahac on September 03, 2006 at 08:09:26:
TV is correct about the noise traveling. I would add if it stops with the clutch pushed in, it has to be input shaft of the TA and down the constant gears to the bottom shaft. Does the thump speed up as you increase engine rpm's? And if the TA is shifted? The speed trany shaft would make the thump speed up or slow down as you shift the 1 thur 4 lever. Seem's like the clutch disc should be OK, but to fix this noise you will be into that part first anyhow. Are you going to tear into it yourself? Drop your Hy-Tran and look in the bucket for pieces of something thats not supposed to be there.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
